주요 콘텐츠로 건너뛰기
Repair information for standalone freezers.
194 질문 전체 보기
Can defrosting break your freezer?
I have a zanussi zvc45 freezer, defrosted it in the afternoon, left it open overnight. the next day it tripped the circuit breaker in the house.
*no evidence of flooding as ice that fell off where removed.
*any fluid that might have leaked were absorbed by towel in front of freezer.
Now when I plug it in, it won’t cool despite adjustments to thermostat
thanks in advance
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
You may need to let it sit for a week to let it dry out. Sounds like water may have accumulated and is shorting out wires. Why did you need to defrost it? What was going on with it?
UPDATE
Most Frequent Causes for Refrigerator not defrosting
Cause 1
Defrost Control Board
The defrost control board determines how often to run the defrost cycle. If the board fails, the refrigerator will not go into the defrost cycle. Before replacing the defrost control board, first test the defrost heater and defrost thermostat. If the defrost heater and defrost thermostat are working properly, the defrost control board is likely defective.
Cause 2
Defrost Timer
The defrost timer turns on the defrost heater several times throughout the day to melt any frost that may have accumulated on the evaporator coils. If the defrost timer is defective, it may not advance into the defrost cycle, or it may not send power to the defrost heater during the defrost cycle. To determine if the defrost timer is defective, slowly advance the dial into the defrost cycle. The compressor should turn off and the heater should turn on. If the timer does not send power to the defrost components or advance out of the defrost cycle within 30 minutes, this indicates that the defrost timer is not advancing. If the defrost timer is not advancing, replace it.
Cause 3
Defrost Heater Assembly
The defrost heater assembly turns on several times throughout the day to melt away any frost that may have accumulated on the evaporator coils. If the defrost heater assembly is defective, the defrost system will not work, and frost will continue to accumulate on the evaporator coils. To determine if the defrost heater is defective, use a multimeter to test it for continuity. If the defrost heater does not have continuity, replace it.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Thanks! I'll do just that. I still get electricity in the unit ( as the hazard light is on) but no humming or clicking sound.
i had to defrost it cause the frost and ice build up was so bad
댓글 달기
귀하의 답변을 추가하세요
Dinno Louis Macandog 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 100
