Cooling problem with refrigerator
Refrigerator is not cooling at all,freezer is at correct temperature. Compressor is working & fan cooling it was not but running now.It is a Samsung side by side.
좋은 질문 입니까?
좋은 질문 입니까?
Cause 1
The Evaporator Coils are Frosted Over
The defrost heater assembly turns on a few times throughout the day to melt away any frost that may have accumulated on the evaporator coils. If the defrost heater assembly is defective, frost will continue to accumulate on the evaporator coils, and the coils will become plugged with frost. If the evaporator coils are frosted over, the airflow through the coils will be restricted, causing the refrigerator not to cool. Check the evaporator coils to determine if they are frosted over. If the evaporator coils are frosted over, test each component of the defrost system.
Cause 2
Evaporator Fan Motor
The evaporator fan motor draws cold air over the evaporator coils and circulates it throughout the freezer. If the evaporator fan is not working, the freezer or refrigerator will not cool adequately. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor..
Cause 3
Damper Control Assembly
The air damper control opens and closes to let the proper amount of cold air into the refrigerator compartment. If the damper does not open properly, it won’t let enough cold air into the refrigerator. Check the damper control to determine if it is broken or stuck closed.
해당 답변은 도움이 되었습니까?
What causes the fridge to make extreme noise
Kate Please try to describe the noise, duration.
Is anyone able to assist with my getting a replacement evaporator fan motor for refrigerator model code RS21DANS1/CHA
Spring, see if that number is RS21DAMS1/CHA
Where can I find the fan?
Hi @fordy ,
Here’s the start of the section in the service manual that shows how to remove the cover from the evaporator assembly so that access to the evaporator fan and the evaporator unit is possible.
해당 답변은 도움이 되었습니까?
so I know this post is old, but I had this problem and did not see my solution so here it is. My samsung refrigerator module number rf20hfenbww top part (the actual refrigerator not the bottom freezer) was not getting cold. After a few days with it unplug I begin to tear it down and found out the the fan behind the inside cover was not running. I had to remove the three screws holding it to the back of the inside wall (be mindful that one of the screws is behind a little tab in the middle of the plate). To my surprise the red wire going to the fan was burned apart, so after rewiring it back together and put everything back together it started cooling again.
해당 답변은 도움이 되었습니까?
My Samsung French door fridge model RF260BEAESG/AA had cooling issue 6 months after warranty expired! It started with water under crisper drawer and fresh food section temperature got to 60F. I called Samsung service department and was told to turn energy saver off, raise the front one inch and manually defrost the fresh food section by pressing two control keys. Few weeks later the problem came back. I took the rear panel off and found ice was all over evaporator and drain hole. I added long T shape metal to keep drain hole from frozen. A couple of month later the problem came back again. Every couple of month I had to take rear panel off. I heard of adding flexible heater and decided to try. Bought a Gemline GH-203 heater and wrapped around the top part of evaporator. Boy it really works. Never have cooling issue again!
Adding heater can create electrical and fire hazard if is not done correctly. I am a retired electrical engineer and have technical knowledge.
해당 답변은 도움이 되었습니까?
Hi @kribaby,
Here’s a link to the start of the diagnostic tests for your model.
It may be a good place to start to see what the problem is.
Looking at the parts for the refrigerator, there are two temperature sensors in the refrigerator compartment, shown as part #9-1 and #10-1 in the Fridge assy/icemaker diagram. The defrost thermostat is part #9-2 in the Fridge assy/icemaker diagram.
해당 답변은 도움이 되었습니까?
I have a Samsung fridge Model RT18M6213SR/AA and my fridge is not cooling properly. The freezer is fine but the fridge is not Cole enough and has started to smell. I checked the Main board and inverter board and I have a solid Red light with no flashing. I removed the cover from the evaporator coils in the fridge and they had a nice light frost so I went on to test the fan motor. I connected a 9 volt battery and the motor started right up. I don't know what the RPM should be but it seemed pretty fast. Next I replaced the Thermosistor but it made no difference. I am having to run the fridge on the highest setting to maintain 38 deg. I tricked the door sensor with a magnet and the fan does run when the door is closed. I am stumped as to what is wrong. Maybe the motor is not running fast enough ? Fridge is only 2 years old and all door seals are like new. Any help would be great.
What is the temperature in the freezer compartment?
- 5 in the freezer.
Not sure if it is applicable to your model but in the parts diagram for the refrigerator compartment they show 2 temp sensors. Part # 10-3 and #14-2 although 14-2 is in a dotted area which may mean that it is an optional extra or feature.
I assume that 10-3 is the sensor that you changed?
Correct I changed the sensor that is housed in the coil cover next to the fan part number DA32-00070A there is another sensor that clips onto the top of the evaporator coil but I did not change it. I think it controlls the defrost mode and I had no heavy frost so I figured it was OK.
After calls to Samsung which was a waste of time I spoke with an appliance repair friend. He said Samsung are prone to icing up. I unplugged and emptied to fridge, doors open for 24 hours. Water appeared on the bottom of fridge, cleaned up the water, plugged it back in and was back to 36 degrees in no time.
해당 답변은 도움이 되었습니까?
Hello. This is happening with my fridge Samsung digital converter. It has been unplugged for 48 hours , water at the back of the fridge in the fridge tray. Do I drain the water and if so how ? It does not come out. Thank you
My fan in the fridge started making a noise (like hitting something) It was ice . I looked on YouTube and seen how to hold the freezer button and the ice button at the same time -it would black out the screen then by pressing the freezer button untill it read “ rd” it would defrost the fridge around the fan. This meaning you hear a beep for about 30 minutes .I had to do this about 4 times to get the noise to stop.
A week later the fridge just stopped cooling -freezer was fine. I looked in the back of the fridge where the two small openings are and on the right side i could see ice-the left hole only had the white styrofoam insulation. I called Samsung they sent out japanese repair man -and he fixed it. The problem was the drain line was too long and kinked -not working properly and a sensor had went bad. total bill was $288.00 plus $95 for service call.
Breakdown of bill -He put a new ice maker in because mine had not worked in two years was froze up and busted. -That problem was caused by the water level was set to fill the trays overflowing causing it to all freeze up. He toally replaced the ice maker.
Fredge—-
Drain kit $24.00
DS $14.00
EG prom $74.00
New ice maker unit $111.00
labor$65
He was there about 2 hours -mainly melting the ice from the freezer and the back of fridge.
I felt the quality of work was great and the price was fair. It has been 2 weeks now everything working great! Hope this helps you !
해당 답변은 도움이 되었습니까?
Hi i have Samsung RB29FERNDSS and i left the door to long and now its not cooling anymore what shoul i do?
Hi @Deejay Aguilar
Have you tried unplugging the power from the refrigerator for about 5 minutes then reconnecting it and check if this resets the refrigerator and it starts working again, you didn't say?
해당 답변은 도움이 되었습니까?
Samsung French door rf263beaesg/aa is not cooling, both main board and inverter board are good and compressors is good
Hi @Luis Hernandez
Here's the troubleshooting page in the service manual which may be a good place to start.
if the compressor is running then the evaporators should be getting icy cold. There is one in the fridge compartment and one associated with the ice maker in the freezer compartment.
if neither are getting icy cold then there is a problem with the sealed system somewhere.
The sealed system includes the compressor, condenser, evaporators, filter dryer and associated piping etc.
Depending on your location the sealed system may need to be checked by a licenced refrigerator repairer, due to the environmental regulations regarding the handling of refrigerant gases. Also they're the only ones allowed to buy it is it has to be replenished if there was a refrigerant leak for instance. They also have the equipment to measure the high/low pressures in the sealed system to know where the problem may be.
When you say the compressor is good presumably you mean that it is operating and is not getting too hot. It may be but that doesn't mean that there is enough refrigerant in the sealed system for it to be cooling properly or there may be a blockage somewhere
How old is the refrigerator?
Check the user manual for the warranty provisions regarding the sealed system for your location. Most manufacturers provide only a 12 month warranty on the fridge but a 5 year warranty on the sealed system (parts only not labour) so it may be worth a look if the fridge is not that old.
Samsung fridge had once maker replaced because it was freezing up. The same day the repair man fixed it, we started hearing a knocking noise. After several visits he kept denying it was a compressor issue. It completely stopped working, and now he says it’s an inverter issue. Any link between the new ice maker and inverter breaking?
해당 답변은 도움이 되었습니까?
Here's a link to a service manual that may help, as usually they have the diagnostic test procedures and wiring diagrams etc to hopefully solve the problem. Unusual that Samsung do not seem interested even if you are willing to pay? :-)
Unfortunately, I couldn't find a free download so you'll have to buy it.
If you do find the problem and it is a faulty part, here's a link to a parts supplier that is useful.
Find the required part in the parts list and then search online for the part number only (this is the manufacturer's part number) to find suppliers that suit you best.
해당 답변은 도움이 되었습니까?
We had an issue with Our Samsung fridge that was similar. Our freezer would be fine, no frozen coils, but the fridge would not cool lower than 47F. I would "reset" the fridge (unplug) for 15 mins then start again and things would be fine for 3 days then go back. I checked the fan, just fine; the damper, just fine; but replaced both of them for the fun of it.. It came down to replacing and relocating the fridge temp sensors . After I did this, no more issues.
Samsung could not figure it out. No one within 100 miles of me would touch the fridge. Samsung sent me the engineering documents on the fridge and told me good luck. The fridge is only 2 years old.
해당 답변은 도움이 되었습니까?
24 시간 전: 21
7일 전: 181
30일 전: 871
전체 시간: 177,865
댓글 25개
Hi,
What is the model number of the refrigerator?
Can you hear the evaporator fan running inside the fridge?
It only runs when the doors are closed. Try listening with your ear near the fridge to hear if a fan stops and starts when you open and close the doors.
If you can't hear a fan running, it is either faulty or perhaps it is iced up and can't move.
If it is iced up it may be a defrost problem e.g. defrost heater, thermostat etc.
jayeff 의
Hello, our samsung fridge Model RS265TDRS/XAA is cooling but the fan is not blowing to move the cold air around to keep the fridge as cold as it normally would be. If the evaporator fan was frozen up but has been since defrosted, could it still need to be replaced? We've put everything back together with limited items in the fridge and it's holding 35 degree's, but the door items aren't as cool as they should be, nor the drawers. The freezer is fine- except the ice maker quit working last year. Not sure if it could be related?
Barb Huddleston 의
Hi samsung refrigerator Model D06042BS800279 compressor is hot and not performing ,please assist
Thulani Mabida 의
Hi my fridge is not working good, freezer is fine but its not cooling
Vsoliel Estrella 의
Sometimes you can find the repair manual online...In the manual, you can look up error codes.....I found my evaporator fan giving an error code....I just received the new fan...old fan worked intermittently
Dave Carlson 의
댓글 20개 더보기
