A/c compressor fuses and relay located
On an 88 honda accord where are the fuses for the a/c compressor and the relay for it located on the car
좋은 질문 입니까?
좋은 질문 입니까?
you’ll have to check Fuse #5 which is the fuse for the clutch relay. The clutch relay should be in the engine compartment on the left fender behind p/s fluid reservoir. There should be two relays. One is for the condensor and the other one for the a/c clutch.. The one with a red wire on the connector is for the AC.
해당 답변은 도움이 되었습니까?
24 시간 전: 3
7일 전: 25
30일 전: 88
전체 시간: 4,377
