주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Envy TouchSmart Sleekbook RT3290 m6-k022dx는 750GB 하드 드라이브, 6GB DDR3 SDRAM, AMD Elite Quad-Core를 탑재하고 있습니다.
How do I replace the battery?
Hi, I need to replace the battery to my HP Envy m6-k022dx (replacement #715050-001). There is an appendage that is attached to the battery, and connects to the computer. I want to know how to remove the appendage without damage. Thank you!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
I think if you are able to just root around a little bit you will be able to find the connector/appendage and then you can disconnect it with a Spudger. Just be careful to not damage it and if it does not come out with the first try keep trying and do not rush it!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
There should be about 12 screws on the bottom of the laptop. Use a PH1 screw driver to remove these screws. Then use a prying tool to remove the back. Once you have the back removed the battery will be right there. Find where the battery plugs into the board and carefully unhook it.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Fatimah T 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 29
전체 시간: 920
