주요 콘텐츠로 건너뛰기
Trackpad Connection Problem
Occasionally I work on early iBook G4 laptops (800 or 933 MHz). Typically, things go very well until I reinstall the top case. Almost without fail, I have problems reattaching the trackpad connector on the top case to the logic board. Since the connector is recessed under the lip of the top case, I seem to have problems lining it up with the pins on the board. I have literally spent hours trying to get the trackpad reconnected -- very frustrating. Is this just me? Does anyone have advice or a trick that might make this any easier?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
I use a small pair of plastic pliers to guide the connector to the socket. The keyboard/trackpad connector is the last connector you clip before closing the top case.
First enter the AC adapter port to the top case hole then align and connet the power switch connector in his socket with a plastic spudger then connect the speakers connector to the speaker socket with the spunger. Once this connector is in place and well connected enter about half to 3/4 inch of the speaker cable in the hole over the speaker socket, if you don't do that you'll have problem to close the top case. Last connector to connect is the keyboard/trackpad connector. Use a small flashlight and light the connector while you're ajusting the top case just over the connector. If you don't have the plastic pliers use the spunger to guide the connector over the socket pins and push it down carefully. If it is not well aligned you will fell a resistance so don't put too much force.
Also (I often made that mistake) before installing the top case on the ibook G4 800 to 1.2Ghz models double-check if the sleep magnet is there under the top case cause the sleep function will not work and you'll have to reopen the case.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Yes, it's very tricky!
Lower the top case until it is virtually leaning on the top shield, then, use a screwdriver or similar to push the connector back so it is directly above the port. Then, push the top case down at the point directly above the connector, making sure the connector is still in position. This may take a few tries but when you get it right the pins will take a very small amount of force to slide into the holes.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Instead of using a metal screwdriver and risking damage, use a plastic spudger or wooden tongue depressor.
댓글 달기
답변을 추가하세요
bookman32756 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 82
전체 시간: 1,669
