주요 콘텐츠로 건너뛰기
모델 A1502 / 4MB 공유 L3 캐시 2.6 GHz (Turbo Boost 최대 3.1 GHz) 또는 2.8 GHz (Turbo Boost 최대 3.3 GHz) 듀얼-코어 Intel Core i7 프로세서.
494 질문 전체 보기
MacBook Pro Keyboard ribbon problem
A Macbook Pro 13” came today to my work shop because 5 keys wasn´t working, I take off the keyboard ribbon and noticed that the contacts were very uggly, I clean it a little with alcohol and then put it back. Now the only key working is the power key. Do the owner needs a new keyboard or there is something I could try???
We are in Cuba, and it is very hard to get spare parts here.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
Not to let anything untried I’d suggest using plenty of good quality flux and heat up nicely the keyboard Zif connector at 250C for a while, being careful not to melt it, rinse with plenty of IPA and blow it with canned air. If you found corrosion on the flat cable there’s certainly also some filth beneath the connector, you might be in luck and be able to recover it with that. If you have donor boards, you might try replacing the connector at once, before purchasing a new keyboard, personally I’d do that first.
해당 답변은 도움이 되었습니까?
점수 4
댓글 2개:
I ask the owner for all the repairing history and it seems that everything happended when somebody disassembly the macbook pro for a clean up, so it seems that the keyboard ribbon get damaged by bad manipulation issues. I managed to find a new keyboard very cheap online, and a friend to get it here, so now all I have to do is wait for the new keyboard. Thank you for your help!!!
Hope everything gets solved with the KB replacement, however you have plan B too :)
댓글 달기
Clean the contacts with a pencil eraser and rinse with alcohol.
Replace the keyboard
Keyboard replacement on mid-2014 MBP Retina
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
If it were my call I would try a new keyboard. iFixit sells the part but however it cannot be shipped to Cuba. Maybe someone can provide an upper case assembly that can be shipped to Cuba.
MacBook Pro 13" Retina (Late 2013-Mid 2014) Upper Case Assembly 이미지
상품
$149.99
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Aaron this is very expensive! Can just the keyboard be replaced (about $25 for the part)?
@mayer Gosh, yeah you are right. I didn't see like a keyboard sold by iFixit so I didn't wanna provide a scam.
댓글 달기
귀하의 답변을 추가하세요
Luis Anniel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 11
전체 시간: 562
