주요 콘텐츠로 건너뛰기
듀얼 마이크와 802.11ac Wi-Fi 연결 기능을 갖춘 Apple MacBook Air 중 더 작은 노트북.
149 질문 전체 보기
How can I backup internal HD to external SSD
Ok, a bit confusing but try to stay with me because I desperately need help.
I removed the internal hard drive from my late 09 iMac 27’
it is a 2 TB stock hard drive. But I only used about 250/300gbs total
I bought a Hard drive dock station and connected it to a friends macbook.
I also bought a 500 Samsung external SSD
i connected that also to the laptop.
I want to transfer all all of my data from my iMac to my SSD using my friends MacBook.
What is is the easiest way to do this ?? Somebody please tell me this is possible.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Install a system, I like Sierra on the external SSD. Do not go to High Sierra because it will try to format it APFS. You want a GUID format. After you format and install the system, boot from it and run migration assistant and select your desired source disk.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
Michael 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 41
