주요 콘텐츠로 건너뛰기
Charging light constantly blinks orange or white
Hi,
I have an HP probook 6475b with a broken screen and want to power it up, however when I plug it in, the charging light constantly blinks orange and when I press the power button, it blinks white 11 times. I am using a Dell power supply instead of a genuine HP one.
Any help appreciated
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Dell power supplies (charger) isn’t quite compatible with the HP chargers. Try a genuine HP charger or one with the proper size.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Yep thanks. After a bit of research I found out that there is a difference between HP power adapters and other ones which makes the laptop think it isn't powerful enough so won't charge. I'll either try applying a voltage to the inner pin or source an HP charger from somewhere. Thank you for confirming my suspicions!
댓글 달기
귀하의 답변을 추가하세요
jamiebrowm 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 10
30일 전: 24
전체 시간: 14,071
