주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2265 질문 전체 보기
iPhone 7: Error 53 after screen replacement (iOS 12)
Hi everyone. My iPhone 7 fell on the floor and the screen got smashed so bad it stopped displaying the image. Lickily, I had a perfectly working iPhone 7 lying around, so I just swapped the whole LCD assembly. The display turned on and displayed the restore required image. But, when I tried to restore, it would stop halfway and then produce the dreaded old error 53. Why is that? I tried DFU restore, replacing the battery, unhooking the rear cam and all combinations thereof. Please help.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Did you transfer the Home Button from the damaged screen to the replacement screen? If you didn’t, that may be why you’re getting this message.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
Thanks, didn't know that. I thought I would boot in and then proceed to transfer the home button. Will try now.
I tore the flex... :\ this is so embarrassing.
댓글 달기
귀하의 답변을 추가하세요
koter 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 166
