주요 콘텐츠로 건너뛰기
While im on youtube or netflix...
the video or movie keeps freezing (pausing) on its own or will pick out the next video on its own. what could be causing this and how do I make it stop? it has been dropped on the floor for the 2 foot tall coffee table.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Prior to dropping the game pad was it doing this behavior you mentioned? If not, something might be broken inside the game pad which would probably be the Digitizer.
Update (09/27/2018)
@justlost Here is a replacement LCD and Digitizer screen assembly and a guide on how to replace the LCD and Digitizer. If it turns out that replacing the LCD and Digitizer display assembly does not solve the problem then you can return the LCD and Digitizer display assembly and get your full money back.
Wii U GamePad Screen
Wii U GamePad LCD Display Replacement
Replace a front glass digitizer screen assembly compatible with the Wii U GamePad Basic and GamePad Deluxe. Features a 6.2 inch (854 x 480) LCD display. 이미지
제품
$24.99
이 답변이 도움이 되었나요?
점수 2
댓글 5개:
ok how do I fix that?
@justlost You did not answer my question. Was this happening before you dropped your game pad?
No it wasnt @ajcooke01
Thanks @ajcooke01 i appreciate that
@justlost No problem! If this solution worked out for you, go ahead and mark it as correct so we can clean up answers and so that other people know what do do.
댓글 달기
답변을 추가하세요
steven_kurzinger 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 164
