주요 콘텐츠로 건너뛰기
Released May 2012, identified by model number J2011-03-US.
45 질문 전체 보기
My Jawbone Isnt Responsive To Me With Or Without Charger
When i hold the button on my jawbone speaker it doesnt turn on or light up, i plugged it in and nothing all i got was a very quick flash of red and i tried to turn it on while it was on the charger still nothing, i listen to it all the time what has happened
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Sadly you likely have a dead battery or the micros USB connection is bad. You can find the needed battery, but the micro USB socket part is hard to find as Jawbone is out of business. Some people have managed to fit other sockets with a bit of work. First test your battery following this guide to get to the leads: Jawbone Big Jambox Battery Replacement if the battery is dead then you’ll need to replace the battery and you’ll then need to check the charging logic as well.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Al-Terrah 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 8
전체 시간: 69
