주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Jawbone Big Jambox Battery Replacement
필요한 것
    1. Jawbone Big Jambox Battery Replacement, Outer Case: 1 단계, 이미지 1개 중 1개
      • Remove both end caps by putting a plastic opening tool in the center of the seam. Work around the edges to pry the end caps off completely.
      • Due to interior clips holding the end caps in place, use caution when applying force.
      댓글 쓰기
    2. Jawbone Big Jambox Battery Replacement: 2 단계, 이미지 3개 중 1개 Jawbone Big Jambox Battery Replacement: 2 단계, 이미지 3개 중 2개 Jawbone Big Jambox Battery Replacement: 2 단계, 이미지 3개 중 3개
      • Turn the Jambox upside down. Peel the indicated rubber tabs off, using a plastic opening tool if necessary.
      • You may want to only take the tabs half way off to avoid re-gluing when reassembling.
      • Remove the three T6, 7.0 mm screws under each rubber tab.
      • Because the screws are a different length, set the screws aside.
      댓글 쓰기
    3. Jawbone Big Jambox Battery Replacement: 3 단계, 이미지 3개 중 1개 Jawbone Big Jambox Battery Replacement: 3 단계, 이미지 3개 중 2개 Jawbone Big Jambox Battery Replacement: 3 단계, 이미지 3개 중 3개
      • With the Jawbone logo facing towards you and with correct orientation, place the Jambox with the left end cap facing upward.
      • Unscrew indicated T6 9.7 mm screws.
      • Gently loosen the tabs from their anchor points so the bottom may be removed.
      • Flip the Jambox so the other end cap is facing up. The USB cable is on this side (metal grounding clip, indicated in orange). Repeat the above two steps.
      댓글 쓰기
    4. Jawbone Big Jambox Battery Replacement: 4 단계, 이미지 1개 중 1개
      • Pry up the bottom panel by lifting from the device.
      • Pull the bottom up. This may take a bit of force as the bottom is glued to device.
      • Once removed, the battery will now be visible.
      댓글 쓰기
    5. Jawbone Big Jambox Battery Replacement: 5 단계, 이미지 2개 중 1개 Jawbone Big Jambox Battery Replacement: 5 단계, 이미지 2개 중 2개
      • Before unscrewing, take a picture of the top view. That way, when you're reassembling the device, you'll know the orientation of the metal grounding plates.
      • Unscrew the eight indicated T6 9.8 mm screws. Remove metal grounding plates.
      댓글 쓰기
    6. Jawbone Big Jambox Battery Replacement: 6 단계, 이미지 1개 중 1개
      • Once all eight screws are removed, pry the sides of the Jambox to lift the body from it's shell.
      댓글 쓰기
    7. Jawbone Big Jambox Battery Replacement: 7 단계, 이미지 1개 중 1개
      • With the battery facing forward, remove the three indicated T6 9.5 mm screws.
      • Once the screws are removed, lift up the small plastic plate, revealing the auxiliary board underneath.
      댓글 쓰기
    1. Jawbone Big Jambox Battery Replacement, Battery: 8 단계, 이미지 2개 중 1개 Jawbone Big Jambox Battery Replacement, Battery: 8 단계, 이미지 2개 중 2개
      • Remove the indicated T6, 7.4mm screw holding the auxiliary board in place.
      • Carefully lift the circuit board up and off to the side.
      댓글 쓰기
    2. Jawbone Big Jambox Battery Replacement: 9 단계, 이미지 1개 중 1개
      • Pull on the red and black cables under the auxiliary board to disconnect the battery.
      댓글 쓰기
    3. Jawbone Big Jambox Battery Replacement: 10 단계, 이미지 2개 중 1개 Jawbone Big Jambox Battery Replacement: 10 단계, 이미지 2개 중 2개
      • The battery is connected to the Jambox with double-sided sticky tape. Use your finger to pry out the battery.
      • Place a new battery in the old battery’s place. Reverse these steps to connect the new battery.
      • When plugging in the new battery, ensure the red and black wires are separated around pegs so that they are not pinched when the auxiliary board is replaced.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 69명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Abby Cybula
회원 가입일: 04/01/15
2,038 평판
안내서 2개를 작성함
Cal Poly, Team 24-5, Lancaster Spring 2015 Cal Poly, Team 24-5, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S24G5
4 회원들
안내서 25개를 작성함
33가이드 댓글
Where do I buy the battery.
Kevin Foti - 답글 공유
http://www.ebay.com/itm/322588700358?ul_... :Here is someone who made and sell the battery for Jambox and Big Jambox, i hope this could be helpful
Lin - 답글 공유
да где аккумулятор купить то?
speedlexx - 답글 공유
на рынке покупаются стандартные 18650 и меняются на старые акку из колонки. что б пошла зарядка нужно дать больше ток.
цена вопроса ~ 1200₽ с работой
Max - 답글 공유
Where do I go to purchase a battery?
Edward Brown - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 64
지난 30일: 285
전체 시간: 75,296
