주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
1525 질문 전체 보기
iPhone 6 Plus Charges after Screen Replacement but doesnt turn on
Hey,
I replaced my iPhone 6 Plus Screen (Complete Screen= Camera, TouchID, Speaker alreadyinstallen on it). If i try to turn it on, the Apple logo shows up and than it`s Black but the Backlight is working. Than it shows the Logo that it’s charging. After couple minute the Apple Logo shows up and again the Backlight is working -> in a loop.
Hope someone can help me!
Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
First of all, if you don’t transfer over the original Home Button, you will lose Touch ID functionality.
As for the problem at hand, I would re-install the original screen to see if the problem persists. If it does, then you may have damaged the logic board during the repair. If the old screen works fine, then you have an issue with the replacement screen. It’s not uncommon for screens that include the Front Camera/Sensor flex to have a defective part. Try not connecting the FCAM flex to see if that solves the problem. If it does, then transfer over your original flex along with the Home Button.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
Badly i cant see on the old screen becaus its damaged, it isn't black the LCD is broken. But i will buy an other screen an try it out.
Start by disconnecting the front camera flex to see if that will help.
댓글 달기
귀하의 답변을 추가하세요
Aruu 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 41
