주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
천장, 상자, 타워 및 스탠드 팬/선풍기를 포함한 모든 가정용 기계 팬/선풍기에 대한 수리 안내 및 지원.
Fan keeps falling over
Hi can someone help I don't keep to good so I have a tall cooling fan at my bed its on 24/7 over the last month it keeps falling over and the tilt keeps dropping down it as if the fan bit is to heavy for the stand. Thank you Susan
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
Hi,
What is make and model number of the fan?
댓글 달기
답변 2개
가장 유용한 답변
In addition to what Dave said, if the pole is wobbly on the stand, there is usually a threaded nut on the bottom of the stand where the pole goes through it. This nut may have loosened up due to vibrations from the fan. Tighten it up.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
I have this problem too but the pole doesn’t go through the base. I see no way that this fan ever stood up? I never paid attention until it just fell over. I am completely complexed.
The feet are usually the weak point , they get stepped on or bent in anyway the fan is basically scrap. Unless you can ‘fabricate’ some kind of home repair .
댓글 달기
Is there a knob on the side of where the fan connects to the stand? If there is try putting it in the position you want and tighten it until the fan stays put. Or, you could fabricate a secondary stand for it to hold it up where you like it to point.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
susangillan35 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 45
전체 시간: 5,411
