주요 콘텐츠로 건너뛰기
Apple의 MacBook Air 13" 2015년 5월 업데이트에는 5 세대 Intel Core i5 및 i7 프로세서가 성능과 배터리 수명을 약간 향상시켰습니다.
623 질문 전체 보기
I broke a MacBook Air backlight by connecting a faulty screen
I received 2 13” Macbook Airs in need of repair: a 2014 model with a cracked (but semi-working) screen, and a 2015 model with water damage, which caused its backlight to fail (but it did work using a flashlight).
When I disconnected the LCD cable from the water damaged Macbook, a few pins on the right side looked slightly damaged, presumably corroded. Wanting to make sure that the backlight issue was caused by a logic board issue, I then swapped the logic boards and connected the water damaged logic board to the cracked LCD. Same thing: no backlight.
Here’s where I made a mistake: to check if the screen on the water damaged Macbook Air was salvageable, I then connected its damaged connector to the good logic board from the other Macbook. I got no image when booting, and then noticed a faint burning smell. I disconnected the battery, and realising I might have made a very bad mistake, I swapped the boards again to see if there was any damage.
Now, the “good” logic board connected to the “good” (but cracked) screen no longer shows a backlight. With a flashlight, I can see the cracked (semi-working) screen. So I basically broke something on the 2015 logic board by connecting a bad LCD connector, causing the backlight to break. Is there anything I can check / do?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
iphone3ghulp  yes, you did. It appears as if you managed to shorten out at least the backlight circuitry. To begin the troubleshooting, you will now have to check the board connector and see if it got damaged as well as check the backlight fuse to see if it has failed.
for further identification etc. it might be helpful if you post some good images of your board with your question. 기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
점수 1
댓글 5개:
Sorry about the comment, I'd understand any noob doing that out of lack of experience, but this question doesn't seem suitable to "a Belgian company specialised in repairing Macs".. :-?
@arbaman I am certain it was the new apprentice that started last week who is at fault ;-)
I really hope so, for customer's and compay's sake..that board only is a week's pay, expensive apprenticeship :-p
No, it was simply me who made the error. I make mistakes sometimes... Anyway it's not like I would charge the customer for it. Thanks for the help oldturkey03, I'll add add pictures tomorrow.
Thanks again, replacing the fuse fixed the issue.
댓글 달기
귀하의 답변을 추가하세요
Cero 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 124
