주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2004년에 출시된 자동 제상 시스템과 결로 방지 히터 스위치를 갖춘 상단 냉동고형 냉장고인 Frigidaire GLRT183TD*에 대한 수리 및 추가 정보입니다. 이 페이지는 GLRT183TD* 패턴과 일치하는 모델 번호에 대한 정보를 다룹니다.
Why my fridge won't run
I bought a used frigidaire refrigerator, model # GLRT183TDWH, it worked and was cold when I bought it. The gentleman said to lay it down in the bed of my truck for transporting. When I plugged it in it ran for about 30-45 seconds then stopped. The lights are working but it's not running.
I don't have the money for another fridge. Please help!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
The gentleman does not know what he is talking about.
Normally it is ok to transport a refrigeration unit in any orientation. The problem arises when it arrives at its final destination. The refrigeration unit is designed to operate only in the upright position. This has to do with the way refrigerant and lubrication oils settle inside the unit when it is turned off. The system is designed to leak down after it is turned off, so that when the it starts again, the compressor can start easily due to the low pressure on the compressor side of the system. If the unit is started soon after righting it, or while it is on its side, refrigerant may build to high pressure levels immediately upon startup. This is a good way to burn out your compressor. In short, there is no issue with transporting it that way, but it is always recommended to let it sit upright for at least a day before attempting to start it.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Chamber leak ho gaya
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Dana 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 16
전체 시간: 365
