주요 콘텐츠로 건너뛰기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
1200 질문 전체 보기
Screw Map For iPhone X
Guys, I have searched the internet for hours trying to find a screw map that shows what size screws go into what holes for an iphone X. I need them all as the phone has been torn down to the bare case.. One of my kids got into my office and knocked my screws and associated drawing onto the floor and now I am screwed (pun intended). Any help would be greatly appreciated
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
There’s no screw map that I’m aware of. You ‘ll need to go through the guides on this page to find most but not all of them. The critical ones are those that screw into standoffs on the logic board. You must use the proper screws for those. You can also look at the iPhone 7/8 series guides if there are some areas that are not covered by the iPhone X guides.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
Thanks for the help. I got the three Stand Off screws covered although the one next to the Tactic Engine wont screw in for some reason. and I have seperated the Tri Point screws from the PH screws. My big concern is the lengths of the screws. I guess I will just guess and not screw down too hard when I am putting in the long ones, And to anybody reading this, I strongly advise you to put the double sided tape onto your drawing and stick the screws down because this is a major pain in the ass !!!
I have the same problem. Have you found any solution?
댓글 달기
great,thank you very much.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I wrote the rear case replacement guide and in the process I followed the example of the guides that had already been written and measured the screws I removed and entered that information in the guide.
In most cases you should do fairly well finding a screw that matches the head style and length as indicated in the guide.
댓글 달기
귀하의 답변을 추가하세요
Sean Wren 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 50
전체 시간: 4,627
