Dryer drum will not spin.
Our dryer drum will not spin at all, tried rotating it by hand by a fin, and its stuck.
좋은 질문 입니까?
좋은 질문 입니까?
The Belt
When it wears out, it puts strain on the motor, causing it to stop. To determine if this is the problem, remove the dryer belt and turn the drum by hand. If the drum is hard to turn and/or makes squealing or grinding noises when turned, the bearing is worn out and needs to be replaced.
UPDATE 4/9/20
If the drum won’t turn, try this video:
해당 답변은 도움이 되었습니까?
24 시간 전: 5
7일 전: 5
30일 전: 13
전체 시간: 572
댓글 2개
Hi
What is the model number of the dryer?
jayeff 의
W10034880 and it won’t spin.. I think something jammed and there was a smell. Timer runs but machine won’t spin; not sure if heating either
Jdesanctis@gmail.com 의
