주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model A1661, A1784, 또는 A1785. 32, 128 또는 256 GB 환경 설정 / 로즈 골드, 금색, 은색, 검정색, 칠흑색 및 (Product)빨간색으로 제공됩니다.
1364 질문 전체 보기
iPhone 7 Plus yellow tint on replaced display. on bottom right
I got scammed on exchange platform,I exchanged my op6+70$ for Iphone 7plus 128gb.
I didn’t notice the tint at that time(night time and I’m in a hurry) ,such a noob mistake. New to IOS device,noticed the tint on bottom right corner,removed tempered glass to make sure it’s not a stain.
Pressure spot on iPhone after screen replacement..
This problem seems similar,Is it same problem /faulty screen ?. I have a bit of experience in repairing mobiles myself(changed screens and such).
Hyderabad,India
Any help is highly appreciated. thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
I don’t know whether it’s a replaced screen or not.
댓글 달기
답변 1개
선택된 답변
It looks like a yellow stain and I suspect that it is caused by a defective or poorly manufactured screen. If you want to be certain, remove the two bottom pentalobe screws and lift the screen to remove any possible pressure points. If the Yellow remains, then you have a bad screen. If the yellow disappears, then something is applying pressure from below the screen.
Either way, look at this guide to help you through the process.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
Nikhil Teja 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 826
