주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Help! Cut iPod Wire!
While trying to replace the digitizer on my iPod Touch, I cut a blue wire by mistake, and i ddin't get my new LCD screen back, so idk if teh battery works. I could hear sounds (voice control) if i click buttons with my headphones but idk about anything else. Does the blue wire that is connected to the battery/iPod beneath the steel plate have any huge impact on the battery or is it just a backup? : (
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
선택된 해법
Rafael, you said that "blue wire that is connected to the battery/iPod" since I can not see what you see, a Picture would be a good thing. But I can almost guarantee you that if it does come from the battery circuit it most certainly makes an impact. It might be that you have cut the battery/charge or control cable. See if you can find the other end where the cable is supposed to connect. Reconnect it and see if it makes a difference :-) Check around the rear facing camera opposite the headphone jack. I think there should be a red one as well..Good Luck and let us know how it is going.
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
i think it is connected to home button and it is right next to a red cable
do you see where it connects to? you may have to resolder it...
The red and blue wire should be the speaker wire. You might want to check if it is still soldered right next to where the red one comes of the board. Check for missing or broken solder pads on that.
댓글 달기
답변을 추가하세요
Rafael 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 5
전체 시간: 2,588
