My vivo v3 not turning on and not charging
i connect my phone to charger for 4 hours later i took my phone was switched off ,iwas turning on but not responding after i connect to same brand charger but not charging,what is the problem
좋은 질문 입니까?
좋은 질문 입니까?
If you let the battery completely die, your phone won’t respond at all when you press the Power button. If the problem was caused by a dead battery, it should boot up normally after plugging it in and let it charge for fifteen minutes or so. .
If it doesn’t work at all, try plugging the device in with a different cable and charger. The charger or cable could be broken and preventing an otherwise-good device from charging.
Android can sometimes hard-freeze and refuse to respond. If Android is completely frozen, your device may be powered on and running — but the screen won’t turn on because the operating system is frozen and not responding to button presses.
You’ll need to perform a “hard reset,” also known as a “power cycle,” to fix these types of freezes. This cuts the power to your phone or tablet entirely, forcing it to shut down and boot back up.
You can remove the battery, wait about ten seconds, and then plug the battery back in and boot it up.
If none of them helped. Your last hope is to take it to a local mobile repair shop or find a Vivo mobile service center to let the expert fix it for you.
해당 답변은 도움이 되었습니까?
https://howtofixgadgets.com/vivo-v3-char...
Just go and check it, I was also facing the same issue but now I have successfully solved this problem.
해당 답변은 도움이 되었습니까?
24 시간 전: 3
7일 전: 23
30일 전: 133
전체 시간: 16,015
댓글 6개
why my Vivo Y55l is bot charging?? my battery is comin to dead
Swera Rebello 의
Battery life time For vivo v3
Mukesh Damor 의
My ViVo v3 was swich off automatically when I am on the network. What's the reason .What's the solution
Sasna Vinod 의
Paano ayusin ang cellphone di sya nag chachage mag on sya pero mag off din bigla
Justine Sabdani 의
Ang cellphone ko ay sira ayw mag charge pero nag oon ma oof lang sya bigla
Justine Sabdani 의
댓글 1개 더보기
