주요 콘텐츠로 건너뛰기
The first of the new generation Nokia devices – the first with a 1080p screen, the first with a quad-core Krait processor
55 질문 전체 보기
The person I phone cannot hear me. Person who rings in cannot hear me
I can hear if I put the "speaker" on but that p icks  up background noise and makes it hard to hear (microphone problem?). Can it be repaired and if so, where? thank  you
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
Hi @bilton ,
As you say it may be a problem with the microphone or it may be that the voice inlet hole. located on the bottom of the phone next to the charge port is blocked with lint etc.
Use a strong light and a magnifying glass to check if this is a possibility.
If it is blocked (or even if you can’t tell) try using a vacuum cleaner to see if this clears the obstruction (if any). DO NOT use a pin or probe to try and clear the hole as you may damage the microphone which is located directly behind it.
If the microphone is faulty, it is available as a separate part or as part of the Dock Charging Flex Cable Assembly, (examples only). Search online for suppliers that suit you.
The microphone is shown on the Dock Charging board in Step.14 of the ifixit Nokia Lumia 1520 Teardown guide.
Here’s the image taken from the guide
(click on image to enlarge for better viewing)
If repairing it yourself is too daunting, contact a reputable, mobile phone repair service, with experience in your make/model of phone and ask for a quote.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Beth 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 6
전체 시간: 72
