주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
iPhone 6 touch screen selectively unresponsive
Yesterday at about 2 pm my screen just stopped responding, it randomly starts functioning for a few seconds, then goes back to not working. I don't think I dropped it because it was working all day yesterday. I've soft reset, hard reset, done a DFU restore, nothing has worked. I don't think I have the "disease"  because there's not grey bar at the top of the screen, the whole screen looks completely fine. Any ideas as to how to fix this?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개
its not working. this website... can u help me again sending link
link seems to be removed deleted
댓글 달기
답변 1개
선택된 답변
Touch Disease is pretty rare on the iPhone 6, it usually afflicts the 6 Plus. That said, there are iPhone 6’s that do require some micro-soldering work to fix cracked solder balls underneath the touch IC’s.
However, before you get there, you have to eliminate the screen as a possibility. You need to try a new or preferably known-good screen to see if the problem remains or not. Only when you have isolated the problem to the logic board should you consider a micro-soldering solution.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Josh W 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 7,812
