주요 콘텐츠로 건너뛰기
2세대 iPhone. Model A1241 / 8 또는 16GB 용량 / 검정 또는 흰색 플라스틱 뒷면. 첫 번째 iPhone보다 수리는 더 간단하며 스크루드라이버, 비집는 도구 그리고 흡입 도구가 필요합니다.
1158 질문 전체 보기
Replaced LCD and phone worked but ear, checked cables now no power
I have an iPhone 3G that had a shattered screen and LCD. I bought replacement parts and did the repair. Everything seemed to be working until I made a phone call and could not hear from the ear piece, only sound would come when put into speaker mode. I read that maybe connector 3 was not fully seated so I went back inside the phone and tried to re-position the connector, now the phone will not turn on. I plugged it in and even after awhile of "charging" it would not even vibrate when the switch was moved. Does anyone know what may have happened, and what I can do?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
check all your connections.. you may have dislodged the power flex (no. 5 or 6... the square shaped connection in the top left of your board) or the display isn't connected so you need to check 1+2, give them a firm press or they tend to pop off when you close up the display.
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
귀하의 답변을 추가하세요
Brandon 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 720
