주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.2 GHz (Turbo Boost 최대 3.4 GHz) 또는 2.5 (Turbo Boost 최대 3.7GHz) GHz 쿼드-코어 Intel Core i7 프로세서.
467 질문 전체 보기
Can I Install a Samsung 970 EVO 1TB on my MBP 15" from 2014?
HI I own a MBP retina display from 2014 SSD model SM0512F, I have been looking on the web to see if possible to upgrade th SSD to the Samsung 970 EVO 2TB, but not sure if this will work and if i will notice any speed improvement?
I will really appreciate any help here!!!
Thanks Nic
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Sorry mate the Samsung M.2 SSD is not compatible with your system. You’ll need either a compatible 3rd party drive from either OWC or Transcend, Or, get the Apple drive from this source: BeetsTech
Review this great guide for the details: The Ultimate Guide to Apple’s Proprietary SSDs
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Thanks for your reply, I read somewhere the there is a connector symatech or something like that can be this use to make incompatible hardware compatible?
You expecting something that is not possible as your system (reference the guide I pointed you to) is a PCIe 2.x based interface (AHCI/PCIe) {Guide - Gen3} where your Samsung 970 EVO SSD is a PCIe 3.x (NVMe/PCIe).
I don't recommend these adapters. Just the other week I had to remove the adapter & SSD someone had installed in both a MacBook Pro & iMac. They just are not that reliable.
I fully understand you want a cheap solution! Sometimes you end up making things worse and in the long run more expensive!
댓글 달기
귀하의 답변을 추가하세요
Nicolas 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 2,079
