주요 콘텐츠로 건너뛰기
Model number A75-S226. Processor: Intel Mobile Pentium 4 3.06 GHz.Installed Memory: 512 MB (DDR SDRAM). Hard Drive: 60 GB EIDE, 4200 RPM.
3 질문 전체 보기
does not connect wifi
where can i get a wifi card for this toshiba?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
bonefont51, give us a bit more information. Why do you think you need a new wifi card? You checked all your settings? Did you check your BIOS, is your wifi recognized? What OS are you using? Anything happened to your computer? Did it stop working all of a sudden?
댓글 달기
답변 2개
선택된 답변
bonefont52, did you check to make sure that you wifi is turned on? Not knowing what OS you are using, I would check the BIOS and see if your wifi shows up and is recognized. Also check on here for more info. Try to reinstall the driver for your wifi, it is available here. If you do want a new card for whatever reason just check on Google there are plenty out there. Good Luck
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
ebay
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
bonefont52 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 4
전체 시간: 1,257
