주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display, 모델 A1502의 2015년 3월 업데이트는 5세대 Intel Core i5 및 i7 프로세서를 포함하며 Force Touch 트랙 패드를 소개합니다.
1185 질문 전체 보기
New battery not fit the slot
Hi all,
I just changed a new battery for the macbookpro 2015 early. I found that the new one can't fit the slot very well, for the bottom frame in the middle. It's a little narrower than the gap, so I can't fit it in. Do you have any idea on how to figure out?
Thanks.
In the following image, the top one is the original battery, and bottom is the new one. Note other parts aligned, but the right point not.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Sounds like you got the wrong battery or a bad copy. Where did you get the battery?
If you can take a picture of both your original battery and your replacement side by side so we can see what is different. You may want to use a ruler to measure them (H-W-D)
기존 질문에 이미지 추가하기
Update (10/25/2018)
Did you follow the IFIXIT guide? MacBook Pro 13" Retina Display Early 2015 배터리 교체
iFixit 이미지
안내서
기존 질문에 이미지 추가하기
난이도:
아주 쉬움
2 - 5 minutes
MacBook Pro 13" Retina Display Early 2015 배터리 이미지
안내서
난이도:
어려움
45 minutes - 2 hours
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
It shows the same model with the original one, and I got it from ifixit. I will measure the length. One thing is that I didn't peel the cover for the adhesive in the back of battery. I am not sure if this affect.
The image is updated. Yes I followed the guide.
@rayfly - Contact IFIXIT using the info on your shipping slip for an exchange. Its possible the battery is defective.
댓글 달기
귀하의 답변을 추가하세요
Lei Xu 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 76
