주요 콘텐츠로 건너뛰기
듀얼 마이크와 802.11ac Wi-Fi 연결 기능을 갖춘 Apple MacBook Air 중 더 작은 노트북.
149 질문 전체 보기
Liquid damage from many years ago. Logic board replacement?
A few years ago I spilled water on my A1465 Macbook Air 11 inch.
Ever since I have used it connected to a monitor. When you shine a flashlight you can see all of the screens and icons on the Macbook. It boots up properly.
Would it be possible to put in a new logic board to fix this issue of the backlight?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
It would also be possible to repair your current logic board backlight circuit. Apple won’t do it, but you can find around a few labs specialized in component level repairs. A board replacement would of course fix the issue too.
해당 답변은 도움이 되었습니까?
점수 3
댓글 19개:
I saw some corrosion around the display data cable. Since I will be getting a new board that will not be an issue.
But I want to know if the LCD data cable will be ok?
@gsjj5 The more the pins are clean and shiny the higher is the change the display was untouched therefore in working condition. I cannot tell for sure at a distance, but the fact you still see the image increases chances it's ok.
@arbaman I'll post a picture here.
Got The connector off. Part of it got corroded away.
댓글 14개 더보기
댓글 달기
귀하의 답변을 추가하세요
George 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 112
