My brake light on dash stays on
Parking brake switch, brake light on dash stays on
좋은 질문 입니까?
Hi @pissingmeoff ,
The “brake” indicator light in the dash has two functions.
It indicates that the parking brake is applied and it is also a low brake fluid level warning light.
If the light is on with the ignition on but the parking brake is released then first check the brake fluid reservoir to ensure that the brake fluid level is correct.
If it is OK then perhaps there may be a faulty sensor in the reservoir or the parking brake switch may be faulty
해당 답변은 도움이 되었습니까?
24 시간 전: 2
7일 전: 7
30일 전: 30
전체 시간: 3,207
댓글 2개
You could bring it to the nearest Mechanic shop and get it fixed there.
First Name Last Name 의
Had all that fixed and it’s still on
James 의
