Lens error, restart the camera
I am getting this message when I press the on button. The lens is not retracting in.
Lens error, Restart the camera.
Can you please help?
좋은 질문 입니까?
좋은 질문 입니까?
Pinky Kasotia , this is usually caused by sand or grit interfering with the lens extension mechanism, or the camera's been dropped with the lens extended. It is also possible that the camera has been powered on, but the lens had been blocked preventing its extension....okay there are plenty of causes. Check on here for a more concise solution. Good luck
해당 답변은 도움이 되었습니까?
lens do not get back when on/off button is pressed.
해당 답변은 도움이 되었습니까?
same answer as above :-)
can you help for restart the camera
해당 답변은 도움이 되었습니까?
Camera lens does not move when switch.
24 시간 전: 5
7일 전: 10
30일 전: 37
전체 시간: 5,821
