주요 콘텐츠로 건너뛰기
Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Sometimes vertical lines on screen
My iPad has been dropped multiple times in the past 3 years or so, although none of them has cause any kind of significant damage, until some time ago, my my iPad would suddenly has thin lines on the screen and experience some kind of image persistence. Most of the time, it was fixed when I restarted it, so I hadn't paid any attention to it. I thought it was a software glitch.
Now it persists on showing the lines on screen. If i press with my thumb on the top right corner and lock and unlock the device it just dissapears. I m just thinking it s a connector problem, but the connectors as I can see on ifixit it s in the top right(let me know if I m wrong). Nothing happens if i press my thumb on the left top of screen.
Any suggestions?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
The screen connectors are on the bottom right. I suspect you just have a bad LCD and seeing as how it;’s been dropped several times, it’s likely the case. LCD’s are pretty expensive so you may want ot consider having this looked at by a shop. Otherwise, you can try yourself by following this guide.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
alexu420 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 465
