How do you change the transmission fluid in the Model S?
Has anyone looked into how to change the single gear transmission fluid in the Model S?
좋은 질문입니까?
좋은 질문입니까?
Stephen Leung this should help you out:
Gearbox Fluid - Front (Remove and Replace)
FRT No: 39300102
Special tool required for this procedure:
SupplierPart NumberDescriptionTesla1054946-00-AFluid Transfer Pan
Gearbox Fluid - Large Rear Drive Unit (Remove and Replace)
FRT No: 40300102
''Warning: If the vehicle has air suspension, activate "Jack" mode on the touchscreen before raising and supporting the vehicle.''
''Caution: Do not attempt to fill the drive unit through the upper plug.''
Toe link
Shock absorber
이 답변이 도움이 되었나요?
This is a guide on how to replace the transmission fluid for the S P85 model. I believe they’re all rather similar in terms of design.
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 5
지난 30일: 33
전체 시간: 5,144
댓글 2개
What kind of oil should I pour into the Tesla model s differential
peretiatkoaa 의
sorry for my english
peretiatkoaa 의
