주요 콘텐츠로 건너뛰기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/64GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
1049 질문 전체 보기
Name of this component for iPhone SE?
Hello, which is the name of this component for iPhone SE? First time with my broke iPhone when I tried to replace motherboard, this component has been removed from iPhone. Which is the function of this component? And is possible repair it with a something as the welder? Because I noticed it is attached to iPhone.
Image of component:
Thank you in advance for reply.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
댓글 달기
답변 2개
선택된 답변
That’s a teared off part of the wifi/bluetooth antenna. It’s a pretty inexpensive part but you’ll have to buy a new one. No need for soldering, it’s simply glued to the housing.
해당 답변은 도움이 되었습니까?
점수 4
댓글 2개:
@refectio That's where it was hidden, thanks for the addition =:)
댓글 달기
That’s part of the rear case. You can see it in this photo from the teardown, and this one too.
To get WiFi/cellular connection, you’ll need to buy a new rear case, since the connector is permanently attached to it, and can only come off if the cable is torn. It looks like you can relatively easily get new (though not necessarily OEM) cases on eBay.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
No, there's no need to replace the housing, it's sufficient to buy the new antenna and replace the part of the old one left, some warming makes the job easier.
Oh, I had no idea that it wasn't part of the rear case!
That's nice to know. Thanks for clearing that up!
댓글 달기
귀하의 답변을 추가하세요
Patrizio Masini 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 79
