Why does my compressor take so long to get up to maximum pressure?
It takes several minutes, more than 20, to get up to maximum pressure. Also after a couple of cycles the compressor won’t start again.
좋은 질문 입니까?
좋은 질문 입니까?
cladoo you did not tell us what you have checked and what exact model your compressor is. I know you picked the device but we just have to be sure. Usually, if an air compressor is taking long to the fill it typically is either a seal problem, gasket failure, or an intake or pressure valve failing. Your “after a couple of cycles the compressor won’t start again “ could also be indicative of an electrical air compressor that is laboring to fill. That could be an issue with the motor/capacitor. If you have a bad run capacitor it would then no longer start. Start by checking on those things and let us know what you find.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 3
30일 전: 22
전체 시간: 6,413
댓글 2개
Is there oil in the compressor?
Hive Army 의
oil less compressor...
pollytintop 의
