주요 콘텐츠로 건너뛰기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/64GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
1049 질문 전체 보기
Home Button Making Very Loud Clicks
Hi,
Whenever I click my home button, it makes a very loud sound and heavy feeling. Is there a way to fix this back to the original and easy click? The home button still works fine. I have not tampered with the home button or ever opened up the phone. It is in good condition and touch id still works.
Any help will be appreciated
Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 4개
Will touch id still be intact if i do this fix?
As long as there is no torn flexes and home key itself doesn't get changed then touch id will still be there.
My suggestion was to just remove clean and refit.
Cheers
thank you, have a nice day.
Thanks! you to :)
댓글 달기
답변 4개
선택된 답변
Idd Start by opening the screen up to see if you have any dirt clogging it up.
it could also be the bracket that holds the home key that has come loose.
This link will show you how to get to it.
iPhone 5s Home Button Replacement
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I FOUND THEE ANSWER! i have the same problem so i opened up the screen of my iphone 8+ and saw that the only reason every time i click the home button its making loud noises is because 1 dirt was in my phone so i cleaned in(brushed it off or blew on it) and then saw a screw was very loose so i tightened just a bit but not too tight and bam went back to normal!! tada!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
honestly based on the answers it might depend how serious the situation was, i was gonna tighten the screw like what one of the answers suggested but they seemed pretty tightened so big brain play here, i powered off and powered back on my phone. Tada!?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Power off and on worked!!!! Nothing more or less
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
TechTalks 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 27
30일 전: 145
전체 시간: 43,427
