주요 콘텐츠로 건너뛰기
DVD catching on eject from Superdrive
iBook G4 1.2GHz
When I put a disk into the drive, it was a little hard on the entry...it feels like it is catching on something, but the drive pulls the disk in. Once it was inside, it played perfectly, no issues at all. Then, when I went to eject it, it feels like the drive is hitting and it starts to grind, like the eject action is working correctly, but something is not letting the disk pass out of the drive through the bezel. If I had to guess, it is some sort of alignment problem.
I read in a simlar post that you can insert a screwdriver into the slot and gently push up on the top of the drive from the slot. Can anyone give me a detailed approach to this, as I don't want to trash my drive or the disk in the doing this process.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 2개
There is no iBook G4 1.25. Please go here to figure out which machine you have. We can then direct you to the correct guide: http://www.everymac.com/systems/apple/ib...
Mayer, this has been edited to reflect the correct model.
댓글 달기
답변 2개
선택된 답변
There's a kind of black textile glued in the slot of the optical drive. It's there to prevent the disk to be scratched when inserted in the drive. After a while the textile can curl and it's become harder to insert the disk and to eject it. To solve the problem you have to remove the optical drive from the ibook, open it, and glue back the textile in place. I've done it many times with success.
해당 답변은 도움이 되었습니까?
점수 5
댓글 달기
I had the same problem, some kind of plastic piece was hanging down. I pushed it up gently with a jeweler's flathead screwdriver and it seems okay now.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ryan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 848
