주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
Is the iPhone 6 battery compatible with the iPhone 6s?
Hi, my iPhone 6s battery says service in battery settings so I came to iFixit to see battery’s. I was wondering if the 6 battery is compatible with the 6s.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 4개
선택된 답변
No, the batteries are not cross-compatible. There are tiny connector layout differences that simply make this not possible. If you look at close-up pictures of the connectors you can see the difference. You can buy the proper battery for your 6s at the link below.
iPhone 6s 배터리 교체
iPhone 6s Battery
iPhone 6s Battery 이미지
상품
iPhone 6s Battery
$29.99
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
+1 on this one. I had the same question when I was fixing a 6s with a dead battery for my father. Learned it the hard way and discovered these batteries are not necescerily cross-compatible. There are size and connector differences that stopped me in my tracks. Not making that mistake again!
댓글 달기
The 6 and 6s have the same battery life but the 6s just has a battery that is a little smaller so it would be better to get a battery made for the phone you have. Plus the cables have different flex connectors.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
wrong. 6 and 6s battery are not compatible by connector
I tried ip6s battery into ip6s.. it's working.
댓글 달기
Nope, they are not. The flex (idk how to call it, the little metal things that you connect to the logic board) is not the same. The may look the same but they are not.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
No
But you change the connectors from spoiled 6 to 6s though the durability isn't determined!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Dahcrazychicken 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 6
7일 전: 46
30일 전: 211
전체 시간: 22,792
