Lost grounding strap while changing battery. Is it needed?
When changing out to a new battery I have misplaced or lost my grounding strap. Is there a substitute I could use to ground the battery? If not, is there someplace I can purchase one.
Will the Ipod function without it?
iPod Nano 1st Generation Battery & Logic Board Replacement
Found small braided copper line....will try and use it for the same purpose.
좋은 질문 입니까?
댓글 2개
is there any way you could post a quick pic of the location of the ground strap you misplaced? I do think I know which one you are taking about, just wanting to making sure.
oldturkey03 의
ah......I see the confusion i have created....apologies.
The grounding wire I am referring too is located inside the Ipod nano. When I replaced the battery, the instructions (step 9) said to remove the batteries ground strap which connects the battery to the logic board.
I can not seem to find the piece once I removed it and am looking for a solution to connect the logic board back to the battery.
sorry for the confusion....i understand the wrist tethered grounding strap.
mlagerton 의
