Is normal what happened to my iPhone?
I would know if is normal with happened with my iPhone SE. After a bad charging in the car, motherboard doesn’t work anymore, and ok, also I readed that motherboard gets a damage after charging in the car without original Apple charger adapter. But this situation seems more serious because I noticed that also display doesn’t work. I put same display in another iPhone SE that 100% works and this display doesn’t work. So, in this case, why also display got a damage?
Thank you an advance for reply.
좋은 질문 입니까?
댓글 2개
Are you sure it’s the logic board? What’s the possibility that it is just the screen that’s broken?
[deleted] 의
I tested also logic board in the 100% iPhone SE working with his display and I can confirm that also logic board doesn't work. On this iPhone I put also that display and I noticed that also display doesn't work. But this situation seems serious, because I readed that after charging in the car only motherboard gets a damage, not also display. So, why also display doesn't work?
Patrizio Masini 의
