주요 콘텐츠로 건너뛰기
The BLU Life X8 is an unlocked Android smartphone (similar to the BLU Life 8 or BLU Life XL) that was released in July of 2015. It can be identified by its Global Trade Item Number 00848958020011.
I cannot be heard during calls
Hey there. So for some reason my phone isn't picking up my voice on calls alone. The voice recorder picks it up fine, but during calls I can't be heard at all. I can hear the other party during the call just fine too.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @tartaurus ,
Use a magnifying glass and a strong light and inspect the voice inlet hole found on the bottom edge of the phone to check if it is blocked with lint or other debris.
It is is (or even if you can’t tell), try using a vacuum cleaner to see if you can clear the obstruction.
DO NOT use a pin or probe to try and clear it as you may damage the microphone which is directly behind the inlet.
If this doesn’t resolve the problem, try using the earphones with the microphone attachment when making or receiving a call. If you can be heard OK when using this, then this proves that the voice transmission circuitry of the phone is OK and that there is a problem with the internal microphone. It is either faulty or has come loose from the systemboard.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
That's just the thing. The mic works fine on everything else. Recording videos, recording audio. Both pick my voice up fine. It's just during calls.
Hi @tartaurus ,
Like a lot of Android phones there are 2 microphones in the phone. One is used for "normal" mode phone calls and the other for "speakerphone" mode or similar type usage where the phone is held away from the face.
Still worth a check ;-)
댓글 달기
답변을 추가하세요
Nick tuttle 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 18
전체 시간: 175
