주요 콘텐츠로 건너뛰기
Repair guides and support for LED, LCD, HD and other Vizio TVs.
931 질문 전체 보기
Now the top half is so dark it’s almost black
Mine started turning blue. Now the top half is so dark it’s almost black. I too was told by Visio that it was not covered under warranty and to buy a new TV. Mine is a 65” SmartCast and about 18 months old.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
mike richardson  post a couple of pictures of your screen with your question so we can see what you see. Ultimately it sounds like a backlight issue. This could be caused by either a bad power board (failing capacitors) or the backlight itself. Remove the back and take a look at the power board. Check first for leaking, bulging capacitors and other obviously damaged components. Post some images of that as well. 기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
mike richardson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 51
