주요 콘텐츠로 건너뛰기
모든 모양, 크기, 색상의 PC 노트북에 대한 수리 안내서 및 분해 정보를 확인하세요.
20 질문 전체 보기
laptop turned black without beeping
My laptop turned black without beeping
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Hi @albert1256 ,
I've moved your comment to a new question so that it will get more attention than being buried in a very old thread.
Please edit your question (click Options > edit)to provide more relevant information which may help people to help you, such as make and model number of laptop, installed OS, is the laptop still powered on, are there any blinking lights etc, and what you have tried to do, if anything, to fix it or see what is happening e.g. have you tried connecting an external monitor? have you tried shining a torch at an angle close to the screen to check if you can detect an image at all. etc?
댓글 달기
답변 1개
It is possible that your battery is damaged, try replacing it and make sure that the 3 connector pins are clean
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Albert enstien 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 30
