My DS lite won’t charge
My ds is fairly old and it hasn’t been charged in years. I tried charging it again but the orange light won’t even show. My charger is new but nothing happens.
좋은 질문 입니까?
좋은 질문 입니까?
This could either be a
안내서
난이도:
쉬움
1 - 5 minutes
안내서
난이도:
운영
25 minutes - 2 hours
안내서
난이도:
매우 어려움
45 minutes
해당 답변은 도움이 되었습니까?
I had a similar issue with my old DS Lite, I noticed while looking into the charging port that it was pretty bent back, I got a flat head screwdriver and pushed it back into place. Although I wouldn’t recommenced using a Flathead screwdriver, I would recommend using a spudger if that’s the issue.
It could be the battery, but if there’s no light at all then I don’t think so, as a DS Lite even without a battery would still make a light when charged.
Good Luck with repairing your DS Lite!
해당 답변은 도움이 되었습니까?
Now that you mention the battery port, I just noticed that it is a slight bit crooked. Maybe that little thing in the middle could be the problem.
I had similar issue too. I have 2 DS Lite, both of them still working and can be charged but recently, one of the are not charging anymore (the orange light didn't even lights up). I can rule out charger issue (since the other one can still be charged as usual) and battery issue, since it can still be turned on, just not charging anymore.
I hope this worked for you!
24 시간 전: 2
7일 전: 10
30일 전: 33
전체 시간: 3,485
