주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo DS Lite Battery Replacement
필요한 것
  1. Nintendo DS Lite Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Nintendo DS Lite Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Unscrew the Phillips screw securing the battery cover to the lower case.
    • The screw remains captive to the battery cover.
    • Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
    댓글 쓰기
  2. Nintendo DS Lite Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
    • Remove the battery from the DS Lite.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 52명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Matthew Newsom
회원 가입일: 01/05/10
42,811 평판
안내서 67개를 작성함
6가이드 댓글
Can you describe the type of screw and captive washer ?
Cornel Paraschiv - 답글 공유
Thank you.
i just ordered a new battery as I already got a new power cord & it won’t charge at all.
Hoping new battery does the trick.
Thanks again.
T. Kellogg
Tamela Kellogg - 답글 공유
Thanks but will a dsi battery work
Zach - 답글 공유
While a very late reply, someone else may find this useful.
In short, no. Not at all. The DS Lite Battery I own (Original) Is listed as
USG-003
3.7v
1000 mAH
3.7 Wh
Where as the DSi battery I own (Again, an original straight from my console) is listed as:
TWL-003
3.7v
840 mAH
3.1 Wh
While the same voltage and a slight difference in capacity, the DSi Battery is slightly longer and slimmer in width to the DS/DS Lite Battery and you will need to find a battery suited for the DS/DS Lite you're using. Many places will sell these batteries but do your research as not all of these are created equal.
kaelowynlee - 답글 공유
My battery cover won’t come off.
Jake - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 19
지난 7일: 195
지난 30일: 847
전체 시간: 76,487
