주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
10MP 디지털 카메라로 5배 광학 줌과 5.7배 디지털 줌, 자동 밝기 조절 기능을 갖춘 2.5인치 선명한 LCD를 탑재했습니다. 24MB의 내장 메모리를 갖추고 있으며 SD/SDHC 카드로 최대 8GB까지 추가로 지원합니다.
Why won't my LCD turn on?
No matter what I do, New Batteries, holding the power button, it won’t turn on
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi,
Does the Status LED above the screen turn on when you switch on the camera?
If it does come on this means that the camera should be on.
If you can, try taking a picture and downloading it to a computer to check the result. I realise that you cannot “see” what you are taking.
If you get a black image instead of a picture on the computer, then there is a problem with either the camera’s image sensor or the motherboard or both. More likely as you can’t see the menu screens either on the camera’s LCD screen then there is a motherboard problem.
If you get a good picture then there is a problem with the camera’s LCD screen.
Here’s a link to the ifixit GE A1050 LCD 교체 guide which may be of some help.
Here’s a link to just one supplier of a replacement part. It is just shown to give you an idea of the cost of the part. There are other suppliers online that may suit you better. Just search for GE A1050 LCD screen part to get results for suppliers of the part.
If it doesn’t come on then most probably there is a problem with the camera’s motherboard or power supply circuit.
The camera would have to be opened and the problem further diagnosed as to the cause.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
James McCurry 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 20
전체 시간: 631
