주요 콘텐츠로 건너뛰기
Repair guides and support for your LG TV.
1343 질문 전체 보기
LG 65LB730 Screen problems, pulsating
Hi, my TV have randomly started pulsating some lines on the objects.
I’ve tried to reset the tv to factory settings and also upgraded/downgraded the fw and problem still issue.
Clip on the issue.
https://www.youtube.com/watch?v=2gs6PVba...
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Jakob Vesterberg
this could be an issue with the main board. Try different video input sources (HDMI, Composite, Coax etc.) and see if it remains. If so, I would consider replacing the main board.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
You are experiencing a TV with an LED problem. Very common. I have repaired these under warranty. Your TV panel is the culprit. You may try to replace the LEDs. This is extremely difficult and can result in a complete waste of time. Recycle and shop for new. Thanks for asking, Matt of Martins TV Repair.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Then I know, thanks for the help :)
댓글 달기
귀하의 답변을 추가하세요
Jakob Vesterberg 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 313
