I can't thank you enough for sharing these troubleshooting tips!
Dealing with a washer that's stuck in the wash can be incredibly frustrating, and I've been there myself.
Your step-by-step guide is a lifesaver, especially for someone like me who isn't exactly a DIY expert.
I followed your advice and started by checking the power source and ensuring the door was properly closed.
It turned out that a loose power connection was the culprit, and a simple fix got my Amana washer back on track.
I was amazed at how something so minor could cause such a major problem.
Your suggestion about resetting the washer by unplugging it for a few minutes also did the trick when the problem persisted.
It's the little things like this that can save us from costly repairs or replacements.
I appreciate your clear explanations and the emphasis on safety throughout the process.
It's evident that you care about your readers' well-being and want us to tackle these issues safely and effectively.
Your blog has become my go-to resource for appliance-related issues,
and I'll be sure to share it with friends and family who might face similar problems with their appliances. Keep up the fantastic work!
댓글 18개
I have a Amanda washing machine that is stuck on wash and doesn’t go anywhere else I have reset the motor 2time all ready does anyone out there know why or what I can do it not that old got it last year
Nana 의
I just had the same problem too check the cold water intake screen take your hoses off the back of the washer and check them screens if them are clogged the machine will not function properly
Jason Christine 의
I just read about the washer fills and stalls at the wash cycle and they have to stand by it and do it manually
carljerue 의
I am really tired of spending hours trying to get my New Amanda was her to go through the entire cycle. It stops after the wash cycle, and then I have to try to get it to rinse and spin, but it just goes back to the wash light ! What can be done to fix this problem?
Bette Moore 의
Hi @Bette Moore
If it is new i.e. <12 months old, follow the manufacturer's warranty directions to get it repaired under warranty.
jayeff 의
댓글 13개 더보기
