주요 콘텐츠로 건너뛰기
Repair guides and support for hair irons, also known as hair straighteners.
37 질문 전체 보기
How can I fix a short in the wire?
I have a Linea pro flat iron with the pants clip. There's a short in the wire and I have no idea where to get it fixed.
Update (04/01/2019)
How could I fix one myself. No wires are exposed. I could take a picture
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
I believe it is where the wire connects. It can swivel and I think it's there. It's a old Linea pro leopard print.
댓글 달기
답변 2개
선택된 답변
See if either one of these guides will give you a clue as to how to open it up to check it for burned components. Use a multimeter to test it for continuity to find the problem.
CHI Original Circuit Board Replacement
Hot Tools HPK12 Cord Replacement
Hot Tools HPK12 Cord 이미지
안내서
난이도:
쉬움
10 minutes
CHI Original Circuit Board 이미지
안내서
난이도:
어려움
1 - 2 hours
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
hello Sora, if you fix it your self it would be cheaper on you. For a shop to fix you would want to compare cost of product to repair cost. Most likely the short would be at the point of where the wire comes into the main unit being pulled out or to short in wire length overall.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Sora Kururugi 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 20
전체 시간: 812
