주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1,000만 화소 Kodak 포인트 앤 슛 카메라.
SD card Is Unusable
My Kodak camera wont let me use sd cards (Iv Tested it on 4 other sd cards and it didn’t work)
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Hi,
Have SD cards worked before in the camera?
What error message if any do you get when fully inserting the SD card?
Have you checked that the cards are formatted and can be read, by inserting them into a card reader connected to a computer?
의 공유
Yes SD cards did work it hasn't ben able to read cards since 2015 and yes All the SD cards I tried worked on my pc
의 공유
댓글 달기
답변 2개
선택된 해법
Your camera may be defective. A more difficult case, since its various components can fail: connectors, camera sensors, elements of the motherboard electronic media. In the latter case, the best way out will be to conduct diagnostics in a specialized center.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Welp I tried, Well I maybe just gona take it apart k
의 공유
댓글 달기
가장 유용한 답변
Hi,
Check that the internal storage setting in the camera is set to Auto
Go to Menu > Setup > Internal Storage.
If it is set to “Internal memory” change it to Auto and see if the SD card is now detected.
If it was already set to Auto or if it still doesn’t work after you changed it to Auto, then there may be a problem with the card reader in the camera.
Unfortunately I haven’t been able to find a service manual or a video that may help in opening the camera so that the problem can be further diagnosed.
Hopefully you may have better luck.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
OK,Well I better just throw it away.
의 공유
댓글 달기
답변을 추가하세요
Matt Pin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 52
전체 시간: 6,312
