주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model A1661, A1784, 또는 A1785. 32, 128 또는 256 GB 환경 설정 / 로즈 골드, 금색, 은색, 검정색, 칠흑색 및 (Product)빨간색으로 제공됩니다.
1364 질문 전체 보기
Replaced lightening connector and now 4G and phone service unavailable
Hi everyone,
I recently replaced my lightening connector in my iPhone 7 plus along with the loud speaker, the new parts work fine as it charges and the speaker is much louder however I can no longer get a signal or 4G at all.
There is a lot of mixed information online but does anyone know which parts may have been damaged and what I should be looking to replace?
Additionally I have tried all the troubleshooting for no service issues such as resetting the phone etc, none of which have worked.
Any answers appreciated, thanks.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
You’ll want to closely inspect the two wires that come from the Lightning Port and connect to the logic board; see Step 35 of this guide.
The actual 4G antennas are embedded inside the lower housing. The mish-mash of screws holding holding the Lightning Port also serve to connect the various embedded antennas to the flex. So start by checking the condition of the wires leading from the flex. Check the connector ends and check the connectors on the logic board. If they are damaged or improperly connected, you will not get signal. Also check to make sure you didn’t mix them up; one is longer than the other and has to connect further up the logic board.
If in doubt, re-install the original flex to see if the signal comes back, that would indicate a faulty Lightning Port, even if it charges and communicates okay.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
aidanstewart 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 72
